Device-Specific Onboarding Instructions
This topic describes how to onboard the following Cambium devices to cnMaestro:
Onboarding cnMatrix
You can onboard cnMatrix through device CLI and using the device UI.
Execute the following command to onboard cnMatrix device connection to cnMaestro:
cnMatrix(config) # cnMaestro url cloud.cambiumnetworks.com
Execute the following command to view the status of cnMatrix device connection to cnMaestro:
cnMatrix(config) # show cnMaestro
Onboarding cnMatrix through UI
In the cnMatrix device UI, complete the following steps:
  1. Navigate to System > Remote Management.
  2. Enter the details in Remote Management section.
  3. Click Apply.
Onboarding cnRanger
To view the status of Sierra 800 and Tyndall 101 connection to cnMaestro, complete the following steps.
Setting static URL for cnMaestro on Sierra 800
  1. Navigate to Configuration > cnMaestro.
  2. Under cnMaestro section, enter the URL in the cnMaestro Address.
  3. Click Save.
Setting static URL for cnMaestro on Tyndall 101
  2. Under cnMaestro section, enter the URL in the cnMaestro URL.
  3. Click Save.
Onboarding cnReach
Onboarding through UI
In the cnReach device UI, complete the following steps:
  1. Navigate to cnMaestro > Management Settings.
  2. Enable cnMaestro Management in Settings section.
  3. Enter your Cambium ID and Onboarding Key.
  4. Click Save.
  5. Navigate to home page to view the status of the cnReach device connection to cnMaestro.
    Figure 1 Onboarding cnReach through UI
    To view the status of the cnReach connection in the cnMaestro:
    Figure 2 Viewing the cnReach connection to cnMaestro
Onboarding cnPilot R-Series
To view the status of the cnPilot R-Series device connection to cnMaestro, complete the following steps:
  1. Navigate to Administration > cnMaestro.
  2. Under cnMaestro configuration section.
  3. Enter the URL in the cnMaestro URL.
  4. Click Save.
    Figure 3 Viewing the cnPilot R-Series device connection
Onboarding through SNMP
The following OIDs can be configured:
Onboarding cnVision
Onboarding cnVision Client
In the cnVision Client device UI, complete the following steps:
  1. Navigate to Configuration > System.
  2. Under cnMaestro section, enter cnMaestro URL.
  3. Click Save.
Onboarding cnVision Hub
In the cnVision Hub device UI, complete the following steps:
  3. Click Save.
Onboarding Enterprise AP
In the Enterprise AP device UI, complete the following steps:
  1. Navigate to Configure > System.
  2. Scroll to Management > cnMaestro.
  3. Enable Remote Management.
  4. Enable Validate Server Certificate if required.
  5. Enter cnMaestro URL.
  6. Enter Cambium ID and Onboarding Key.
  7. Navigate to Dashboard to view the status of the Enterprise AP device connection to cnMaestro.
    Figure 4 Onboarding Enterprise AP through device UI
To view the status of the device connection to cnMaestro:
Figure 5 Viewing the Enterprise AP connection to cnMaestro
Onboarding ePMP 1000
In the ePMP device UI, complete the following steps:
  2. Scroll to cnMaestro.
  3. Select Enable and enter your Cambium ID and the user’s Onboarding Password.
  4. Navigate to Monitor > System to view the status of the ePMP device connection to cnMaestro.
    Figure 6 Onboarding ePMP 1000 through UI
    To view the status of the ePMP device connection to cnMaestro:
    Figure 7 Viewing the ePMP device connection to cnMaestro
The following OID can be used to check the status of the device’s connection to cnMaestro.
Onboarding PMP
To onboard PMP device connection to cnMaestro:
In the PMP device UI, complete the following steps:
  2. Under Configuration, provide the following details:
    1. Select Enable under Remote Management.
    2. Enter the URL to connect to cnMaestro in the cnMaestro URL textbox.
  3. Under Credentials, enter the Cambium ID and the Onboarding Key in the respective textboxes. The Account ID field displays the account id of the user.
    Figure 8 Onboarding PMP through UI
    To view the logs, navigate to Logs > Device Agent Log page:
    Figure 9 Viewing Logs
The following OIDs can be used to check the status of the device’s connection to cnMaestro.
Onboarding PTP 650/670/700
  1. Navigate to Installation click Run Installation wizard button.
  2. In the Management Configuration window, under cnMaestro, select Enabled.
  3. Select cnMaestro Cloud radio button.
Onboarding Xirrus device
Perform the following steps to onboard Xirrus device through CLI.
  1. Connect to the device using any SSH tool.
  2. Login as admin, the default password is admin.
  3. Execute the following command in ssh console:
    #ssh admin <device IP address>
    #password <admin>
    #configure
    #management
    #cloud server cloud.cambiumnetworks.com scheme cnmaestro enable
    #save
    #Saving configuration...OK
    #cnMaestro-onboarding id cambium_ID key onboarding_key
    #save
    saving configuration...OK
    #show management
    Cloud Management enabled Cloud Timeout 50 seconds Cloud Port 443 Cloud Retry 5 Cloud Scheme cnMaestro Cloud Server cloud.cambiumnetworks.com
    Cambium ID NOTSET Cambium Key Set cnMaestro Status Not Connected
  4. Login to Cloud account.
  5. Navigate to Home > Onboard > Devices.
  6. In the Devices page, the device onboarded is shown in Figure 10
    Figure 10 Xirrus Device Waiting for Approval
    The Status field display Waiting for Approval.
    It is optional to provision the device for location, software version update, and assign to an AP Group.
  7. Click Save.
  8. Click Approve.
For details to migrate Xirrus devices from XMS to cnMaestro X using a tool, see XMS-Enterprise to cnMaestro X.
Note
  • Xirrus APs are onboarded only to cnMaestro X accounts not to cnMaestro Essentials.
  • Tier 3 subscription is applicable to Xirrus APs.
  • Xirrus devices can only be onboarded using Cambium Id and Onboarding Key for Cloud account.
Onboarding a cnWave 5G Fixed BTS device
Claiming the cnWave 5G Fixed BTS device
To claim the cnWave 5G Fixed BTS device, you must have access to the device GUI. In the cnWave 5G Fixed BTS device UI, complete the following steps:
  1. From the main home page, navigate to System > General.
  2. In the cnMaestro section, enable Remote Management.
  3. In the Address field, enter the cnMaestro URL or IP Address.
  4. Enter your Cambium ID and Onboarding Key. Validate Server Certificate is an optional field.
    Note
    You can enter a valid Cambium ID and Onboarding Key in the cnWave 5G Fixed BTS device UI, when Allow device to be claimed using Cambium ID option is enabled in the Settings section in the cnMaestro Onboard page.
  5. Click Save.
    When the cnWave 5G Fixed BTS device is onboarded to the cnMaestro for the first time, the Connection Status field in the cnWave 5G Fixed BTS device UI displays Device Approval Pending as shown in Figure 11.
    Figure 11 Device Approval Pending status in cnWave 5G Fixed BTS
  6. In the cnMaestro UI, navigate to Onboard > Devices and click Approve, as shown in Figure 12.
    Figure 12 Approving the cnWave 5G Fixed device using the cnMaestro UI
    The cnWave 5G Fixed BTS device is onboarded to cnMaestro.
    Figure 13 Viewing the cnWave 5G Fixed BTS device onboarded in cnMaestro
    The Connection Status field in the cnWave 5G Fixed BTS device UI displays Connected, on approval, as shown in Figure 14.
    Figure 14 cnWave 5G Fixed BTS device Connected
To view the cnWave 5G Fixed BTS device in cnMaestro, complete the following steps:
  1. From the cnMaestro UI home page, navigate to Monitor and Manage > default network or navigate to Onboard > Devices.
  2. Click on the Onboarded link.
    Registered cnWave 5G Fixed CPE devices are also onboarded along with cnWave 5G Fixed BTS device.
    Figure 15 Viewing cnWave 5G Fixed BTS device and registered CPE devices
Claiming the cnWave 5G Fixed BTS device with a Serial Number
To claim and onboard the cnWave 5G Fixed BTS device, complete the following steps:
  1. From the home page of cnMaestro, navigate to Onboard > Devices tab.
    The Onboard page appears with details of the devices and their serial numbers, as shown in Figure 16.
    Figure 16 Onboard page
  2. Click Claim Device located at the right side of the Onboard page, as shown in Figure 16.
    The Claim Devices with Serial Number page appears, as shown in Figure 17.
  3. Enter the serial number of the cnWave 5G Fixed BTS device in the text box, as shown in Figure 17.
    Note
    You can also place the cursor in the text box and use a barcode scanner to quickly claim the devices.
    Figure 17 Claim Devices with Serial Number page
  4. Click Claim Devices.
  5. To onboard the cnWave 5G Fixed BTS device, click Approve located at the right side of the Onboard page, as shown in Figure 18.
    Figure 18 Onboarding Queue
    Note
    If you do not click Approve, the device remains in the Onboarding Queue.
Onboard Edge Controller
To onboard Edge Controller, complete the following steps:
  1. Enter cnMaestro URL or IP address, Cambium ID, and Onboarding Key in CLI.
  2. Navigate to Onboard > Edge Controller > Controllers.
  3. Click Approve.
    Figure 19 Edge Controller
Onboard PTP 820/850 devices
To onboard PTP 820/850 devices, complete the following steps:
  1. Ensure SNMP rules are added in Edge Controller configuration.
  2. Navigate to Onboard > Edge Controller > Devices.
  3. Click Approve.
    Figure 20 PTP 820/850 devices
Onboarding the NSE 3000 Devices
Note
If the device needs static IP or other WAN configuration to be connected to the internet, refer to Device UI Configuration.
This section describes the onboarding of NSE 3000 to the cnMaestro Cloud X account. The onboarding process requires the device Manufacturing Serial Number (MSN). The MSN of the device can be found at the bottom of the device as shown in Figure 21.
Figure 21 : MSN of device
To onboard the device, complete the following steps:
  1. Open a web browser and type the URL https://cloud.cambiumnetworks.com.
    The sign in page appears.
  2. Create a new cnMaestro X account or select an existing cnMaestro X account. A tier 30 subscription is required.
  3. Navigate to cnMaestro Home > Onboard > click Claim Device.
    Figure 22 Onboard page
  4. Claim Devices with Serial Number window pops up.
    Figure 23 Claim devices with Serial Number
  5. Select the Managed Account from the dropdown.
  6. Enter the Serial Number (MSN) of the device in the text box.
  7. Click Claim Devices.
    The device will be listed in the Onboarding Queue.
  8. Click the Approve Device () icon or Approve All at the right side of the Onboard page, as shown in
    Figure 24 Approve
    When device is approved appears on the Onboard page as shown below in Figure 25.
    Figure 25 NSE 3000 Device Onboard
Onboarding Home Mesh Routers
To onboard the Home Mesh Router to cnMaestro, see Onboarding the Home Mesh Router to cnMaestro.
Claiming the Home Mesh Router on the cnMaestro Cloud's Onboard page is not supported.
Onboarding PON devices
This section describes the onboarding of PON devices to the cnMaestro X account. The onboarding process requires the device Manufacturing Serial Number (MSN). The MSN of the device can be found at the bottom of the device as shown in Figure 26.
To onboard the router, complete the following steps:
  1. Navigate to cnMaestro Home > Onboard.
    Figure 26 Onboard page for PON devices
  2. Click Claim Device.
    The Claim Devices with Serial Number window is displayed.
    Figure 27 Claim devices with Serial Number
  3. Select the account from the Managed Account dropdown list .
  4. Enter the Serial Number (MSN) of the device in the text box.
  5. Click Claim Devices.
  6. Click the Approve Device () icon.
Onboarding 60 GHz cnWave devices
You can onboard a 60 GHz device (V1000, V2000, V3000, or V5000) to cnMaestro with the End-to-End (E2E) Controller enabled. E2E Controller handles important management functions such as link bring-up, software upgrades. and configuration
A cnWave network is managed by a central controller called E2E Controller. Each cnWave node (V1000, V2000, V3000, or V5000) rubs minion (client) that connects to the E2E Controller. The controller can run on any host with a route to the cnWave network, including a cnWave node itself.
60 GHz cnWave devices support the following E2E Controllers types:
Based on the E2E Controller type hosted on the 60 GHz device, the onboarding process varies. Without the E2E Controller enabled, the onboarding of 60 GHz devices is not supported in cnMaestro.
Note
Before onboarding a 60 GHz cnWave device (V1000, V2000, V3000, or V5000), ensure to complete the following prerequisite tasks:
  • Ensure that the required E2E Controller type is hosted on the 60 GHz device. For detailed information on deploying the E2E Controller for the 60 GHz device, refer to the 60 GHz cnWave E2E Controller User Guide.
  • Enable the E2E Controller (after hosting) using the device UI. For detailed information on enabling the E2E Controller for the 60 GHz device, refer to the latest 60 GHz cnWave User Guide.
  • Ensure that the IP address of the E2E Controller is set. The E2E Controller and cnMaestro are two separate entities and they can be hosted on separate computers or the same computer. The E2E Controller uses IPv4 to communicate with the cnMaestro and uses IPv6 to communicate with the cnWave radios.
This topic covers the following sections:
Onboarding a 60 GHz device with external E2E Controller
To onboard a 60 GHz device with the external E2E Controller, complete the following steps:
  1. Ensure that the 60 GHz cnWave E2E Controller package (OVA file) is installed on a Linux machine or Oracle Virtualbox (which is used for device management).
  2. Set the IP address of the external E2E Controller.
  3. At the console, SSH into the external E2E Controller using its IP address.
    The cnWave E2E Controller Terminal UI (TUI) opens.
  4. Navigate to the cnMaestro option.
    The Configure cnMaestro Management Server window opens.
  5. Set appropriate values for the following parameters:
  6. Click Update.
  7. From the home page of cnMaestro UI, navigate to the Monitor and Manage > Network and select a 60 GHz cnWave network. Example: 60 GHz cnWave E2E
  8. Click Approve.
    The 60 GHz cnWave–Network Onboard window appears. By default, Auto-assign is selected. You can select Auto-assign or Manual.
    When you select Manual, you can update IPv6 address for the E2E Network. You must wait until the IPv6 address gets updated. If Auto Generate IPv6 Addresses is enabled, the E2E Controller fetches the IPv6 addresses automatically.
  9. Set the required parameters and select the Enable Layer 2 Bridge checkbox, if required.
  10. Click Apply and Wait until the network onboard is successful.
    Note
    The Onboard page in cnMaestro UI supports a separate tab for 60 GHz cnWave. Using this 60 GHz cnWave tab, you can check the onboarding queue for E2E Controllers and cnWave devices. Users must approve the60 GHz E2E Controller before it is added to cnMaestro as an E2E Network. The users can approve either through the Onboarding Queue or the Hierarchical Tree (where the E2E Network is placed on the Monitor and Manage page).
    When the onboarding is approved, the 60 GHz cnWave E2E Network (and its devices) can be managed by cnMaestro.
    When the onboard is successfully complete, the cnMaestro UI displays the External E2E Network dashboard as shown in the figure below. The icon indicates the External E2E Controller network.
Onboarding a 60 GHz device with Onboard E2E Controller
To onboard a 60 GHz device with the internal Onboard E2E Controller (which is running on the 60 GHz cnWave device), complete the following steps:
  1. Ensure that the external E2E Controller is enabled using the device UI. For details, refer to the 60 GHz cnWave User Guide.
  2. Ensure that the Onboard E2E Controller is enabled using the device UI. You can set the remote management settings, including Cambium URL, Cambium ID, and onboarding key. For details, refer to the 60 GHz cnWave User Guide.
  3. From the home page of cnMaestro UI, navigate to the Monitor and Manage > Network page and select a 60 GHz cnWave network.
  4. Click Approve.
    The 60 GHz cnWave - Network Onboard window appears.
  5. Edit the network name and click Save.
    You must wait until the network onboard successful message is displayed.
    When the onboard is successfully complete, the cnMaestro UI displays the Onboard E2E Network dashboard as shown in the figure below.
    If a PoP node is running the Onboard E2E Controller, then the icon indicates the PoP as shown in the figure below.
Onboarding the Onboard E2E Controller using Serial Number
To onboard the internal running 60 GHz Onboard E2E Controller using its serial number, complete the following steps:
  1. From the home page of cnMaestro UI, select Onboard and click the 60 GHz cnWave tab.
  2. Click on the Claim Onboard E2E button.
    The Claim Onboard E2E Network with Serial Number windows appears
  3. Enter the serial number of the 60 GHz cnWave devices and click Claim Devices.
