This section provides the following topics:
Existing networks can be onboarded by setting Cambium ID on already-deployed devices over SNMP (see the section on Device-Specific Onboarding for details on the OID). These devices will contact Cambium Cloud and be mapped to the corresponding Cloud Management. To complete onboarding, the administrator should navigate to the Onboarding Queue and approve all devices.
New devices are onboarded either using Cambium ID (which is a requirement for serial numbers less than 12 characters in length) or through the Serial Number.
First, make sure Cambium ID support is enabled, and a password field is set.
Navigate to and click .
Select
Click
Choose the name of the user from the drop-down list.
Enter the key for the user in the textbox. The minimum length of characters for the key is 8.
Click .
Launch the device UI and enter the Cambium ID and password. The example below defines how to set for ePMP.
Login to the device UI and navigate to .
Enable the radio button for enabling
Enter the cnMaestro cloud URL in the cnMaestro URL textbox.
Enter Cambium ID in the textbox.
Enter the Onboarding key in the textbox.
Click the device.
Approve the device for onboarding:
Navigate to and click thetab.
Find the device and onboard using the Cambium ID.
You can able to see who onboarded the device.
The Status field should display .
Make any additional onboarding configuration changes you want.
Approve the device by clicking the Approve button under .
The device status will change to after onboarding finishes under the Status.
Devices can be claimed over SNMP by using the Cambium ID and Onboarding Key. See Claiming Devices with Cambium ID section for devices you would like to onboard in this way.
